Hey guys, was wondering if you could help me and a mate out. We are unsure as to whether his Silvia (Q) has a CA18 or a SR20. So I was wondering if I could borrow your knowledge and help us out :) Here are the facts:
It says 2 litre on the engine casing.
It has SR20 on the sticker on the under side of the bonnet.
It says CA18 on the metal stamp next to the import stamp.
It is a 1991 model. (I think, it may of been imported in 1991)
We are unsure which to believe, the company in which he bought it from said it was a CA18 so it doesnt matter if it is, he didnt get ripped off or anything, we are just interested.
Cheers for any help in advance :)
https://www.sau.com.au/forums/topic/27412-is-it-a-ca18-or-a-sr20/
mad max:
Is the boot badge a circle or more square?
The SR20's have a circle, the CA18's have more of a square boot badge.
Also the SR20's have round halogen lights (99% of the time) and the CA18's have the better looking square headlights.
dkonig: Be careful not to spread misinformation.. SR20's have a red rocker cover, CA18's should have a silver one.
To confuse tihngs even more, it might be a CA18 with an SR20 Engine dropped in it. :)
But yes, '91 models and above are SR20's.. And no, it would have certainly not been imported in 91.
I have not spread any mis-information, the third silver rocker covered SR20DE I have owned is parked in my driveway.
silver rocker cover with distributor rather than coil packs is from S13 Q
S13 K had the red cover and the coils
LATE S13 K had the blck rocker cover with coils but NO VVT (not sloped at the back of the cover)
S14 had the black cover but sloped at the back for vvt
S15 sort of grey colour, also sloped at back
Attached a pic of my DE (and yes I know thats a turbo on it :)
CA18DE were all Red Rocker covers except for a CA18e which was a carby smaller version of the R31 pintara motor CA20e, the ca18e which had a silver rocker cover, but this motor was only ever a Single overhead cam jusst like the CA20e.
Guest Sphyncter
ive got a ca18de red rocker silvia. dont worry about the badging and stuff cause thats no good to ya. you should be able to go from the metal stamp (next to import stamp) because these are meant to be changed whenever engine is changed (duh!) because it should have engine number on it and stuff. i know mine has had a 2L in it at some stage, but its back to the 1.8. check the metal badge, if that says 1.8 then id say its 1.8. as the guys said, without a pick we can't help ya.
as for headlights guys, mines an 88 and its got the round globes, not the square!!
-Pat
And this has been my 2 cents.....
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
    • I've never understood why this bothers people. Surely you'd be looking at a T3 flanged Garrett style thing, rather than a TD? You're unlikely to push a +T hard enough to need that much fuel. If you're not starting with most of the things you need to do that (ie, the bloody ECU!), you're better off just going Haltech/Link. You wil hate life a lot less. No. Just no. Just turbo it as is.
    • Have you noticed if the squeak changes with temperature or after driving in the rain?
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
