  • Replies 46
anyone seen whiter/brighter HIGH beam globes for sale? mine are not bright enough for out here in the bush :D
got whiter globes in the low beam and really tell the difference when switching from high to low beam!!!
Does anyone have any technical (non-marketing) info on these?
Rezz, running 90w globes in place of the standard ones is risky as the stock wiring isn't rated to carry that load. It'd also be inconsiderate and illegal to run them as your normal beam. 90w as high beam with upgraded wiring is a good idea though and less likely to be targeted.
Craved, high beam globes are the same as low beam globes. If uprated globes for high beam aren't enough for country driving, look at dedicated driving lights.
I suspect these Raybrig lights are similar to the current range of xenon halogen globes most lighting manufactures have out. They aren't standard replacements so you'll have to ask for them by name. eg Philips VisionPlus.
Grandenko, thanks very much for that, I overlooked the wattage rating.
But I understood (with the Raybrig globes) that 90w was when hi-beam is on? Usually the globes are 55w on lo-beam...?
Just wondering about cars like the R33 which have a separate globe for the high beam! is there a straight 90w option for these as they would have to be different ratings as the low beam lights turn off when they come on! therefore for our cars the low and high beam are not the same globes!
"Craved, high beam globes are the same low beam globes. If uprated globes for high beam aren't enough for country driving, look at dedicated driving lights. "
hehe, dont really think driving lights would suit the skyline :D
any suggestions?
Originally posted by Rezz
Craved, Raybrig say the RR15`s are for the "4 headlight" cars as well... I guess that means R33`s.
so they only sell the one globe for 4 headlight cars? what does the plug for the lights look like? are they normal single blade fitting? or tri blade?
Guys, guys...
Forgive me if I`m wrong, but aren`t there 2 elements in each globe? If your car has only one globe per headlight, on low-beam, the 50-odd watt element lights up... and on high-beam, the 90 watt whatever element lights up?
I understood that if you wanted these "HID type" halogens on a 4-headlight car, you have to decide whether you want to upgrade the low-beam or high-beam...
Am I wrong? I`ve only ever seen these Raybrigs on my brothers PAS trophy winning Toyota LiteAce (which is a 2 headlight van) and they were normal wattage on low-beam, and a higher wattage on high-beam.
In the R33, they are 4 headlight: 2 on low beam, other 2 on high beam! low beam lights are definately only single element lights, so would assume the same with high beam as only one on at a time eg 2 outside lights on on low beam, 2 insides lights only on high beam!! therefore the globes must be of different output wattage!
ps did you get my email Rezz?
Are you sure they're not the same wattage? Just angled higher?
Because i want to purchase Phillips Blue Vision H1 55W for the low-beams, they come with the parkers. Then a set for whatever the High-beams are, and also find out what bulbs i need for the lights in the front bar of the Series II, cause i always drive with them on, and they'd need to match.
Sorry, what I meant by "high beam globes are the same as low beam globes" is that both low and high beam use the same type of globes - H1. There are seperate globe holders/lamp assemblies for each and they both use H1 55w globes. The only difference, funnily enough, is that the high beam lamp is physically aimed higher than the low beam lamp. 90w bulbs for the high beam lamp would be a good idea though, along with the required wiring upgrades.
Rezz, I think you're talking about H4 globes, they have 3 pins and 2 filaments of different wattages. Some cars use a H1 for high beam and a H4 for low/high beam.
hey, are those lights on the front bar actually giving off light, or just looking nice!!! if it was to look good, try following this thread to make them look real nice and white!!
LED LIGHTS - these look good
Do you know what would need to be upgraded to run higher wattage high beams lights? also i haven't seen brighter lights in higher wattage in normal shops!
Ryan D didn't seem to have any issues, he's saying that he was running 90W in his car!
interested to see what comes of this though! also is there any lights about say 70W or so, something brighter, but not enough to blind oncoming traffic!!
You'd have to speak to an auto electrician or car audio installer about wiring upgrades. Its just higher gauge +ve cable run via a relay and a new earth. Ask them about the risks of running 90w globes in place of standard 55w globes.
I really would leave high wattage globes for high beams only.
Yourve all confused the shit out of each other for no reason,
The R33's lights, both low and high beam are h1 type
lowbeam = 55w
high beam = 90w
the wiring is suited to this, even more wattage if wanted.
If yourve got an R33 just get two packs and replace all the lights.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
