Hey Guys,
Just have a sub and some rims + tires for sale, I need to buy a bed and subs and wheels are not very comfortable to sleep on ;)
The sub is a home unit - 12" Isobaric 350WRMS, basically 2 carbon fibre subs one in front of the other in a big box. I built it a few years ago and it cost about $1400 at the time. It could do with a bit of paint tho, but it still pumps pretty hard if you want it to, I went a bit over the top so I wouldnt need to thrash it. It has not had much use for the last two years, but its hooked up at the moment so you can have a listen - bring your own music to give it a test :thumbsup: Its a pretty big unit and takes two people to lift it! Chasing about $500
Skid rims- stock r32 rims with some goodyear rubber, there is a bit of tread left on them but two of them have some camber wear on the outside, plus there is a spare tire. After about $180
Located in hobart, prices negotiable - I dont have a mobile, so shoot me a pm and I will give you a call, thanks
https://www.sau.com.au/forums/topic/274631-fs-sub-skid-rims/
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
