Hey Guys,
Just have a sub and some rims + tires for sale, I need to buy a bed and subs and wheels are not very comfortable to sleep on ;)
The sub is a home unit - 12" Isobaric 350WRMS, basically 2 carbon fibre subs one in front of the other in a big box. I built it a few years ago and it cost about $1400 at the time. It could do with a bit of paint tho, but it still pumps pretty hard if you want it to, I went a bit over the top so I wouldnt need to thrash it. It has not had much use for the last two years, but its hooked up at the moment so you can have a listen - bring your own music to give it a test :thumbsup: Its a pretty big unit and takes two people to lift it! Chasing about $500
Skid rims- stock r32 rims with some goodyear rubber, there is a bit of tread left on them but two of them have some camber wear on the outside, plus there is a spare tire. After about $180
Located in hobart, prices negotiable - I dont have a mobile, so shoot me a pm and I will give you a call, thanks
https://www.sau.com.au/forums/topic/274631-fs-sub-skid-rims/
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
