im goin to come for a look
if anyone needs a tow let me know
Reckon im gonna just do the praccy and also head out to watch the modern comp. Depends if my gearbox holds, as it is crunching 3-4th at high rpm :cool:
So can i hitch a ride with anyone :)
  • Replies 49
Mine does the exact same crunch changing from 3rd to 4th at peakpower, delay the shift for a second longer and mine doesn't crunch.
It's crunching because your syncro's are worn, you can reduce the amount they play up but trying some different thickness G/Box oil. there are different schools of thought as to whether to use thicker or thinner oil but i found that thicker oil worked in my box and now it never crunches. Having said that a slow shift is better for the box than slamming through the gears.
I wont be coming out, I really need to upgrade my brake lines and replace my brake fluid and also buy new pads, have less than 2mm left on my front pads after last prac day. Seriously think i'll have to upgrade brakes brakes soon, brakes are at their limit and i dont think they will take this punishment for much longer :) Why do good brakes have to cost so damn much :D If anyone knows of some good brakes for sale let me know :P
hey guys, is this like pretty much the same set up as drift practice, as in you can just pay on the day and have track time? or you you need other CAMS licence. Is it a competition so its all competeting against other cars or just practice? . is it open to any car? im keen to get my car on the track as i hardly get too drive it anymore, cheers.
rock up in the morning,
pay $100 + $25 for day licence if you dont have a cams one
get 5-6 sessions of 15min practice runs... no racing, no overtaking under brakes or into corners
Edited by SkyHi_33
hey chad, if youre serious about upgraded brakes, i know a guy on 31 club has picked up a couple sets of porsche brakes and is onselling a few (had to buy a half dozen sets to get a good price), might be a little overkill though...
calipers for 33 gtr aka 330 rather than the stock r32 296's ? or do u mean just the hubs and that the calipers fit with that size?
-D
You just need to cut off the dust covers, but other then that, everything bolts up fine. GTR disc's are 330mm front.
why not just go aftermarket slotted then.....
I am pretty sure there is a group buys section on slotted rotors in the main for sale section.....got my brakes from that GB and are awesome rotors....so far not a problem and going welll
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
