Hi all,
I've just got a few things that are lying around that I don't need.
1. Pair of standard S15 rear struts = $80
- Taken off the car at approx 10000kms. In excellent condition
2. Pair of standard S15 front springs and S14 front struts = $40
- S15 springs were taken off the car at approx 10000kms and are in excellent condition. The S14 struts were taken off my car at approx 50000kms, but have seen better days.
3. Pair of Whiteline front swaybar links = $50
- These are brand new and have never been installed. To suit s14's and s15's.
4. 2 x Super Start car batteries = $60 each
- Model number: NS50Z
- CCA = 430
- Plates = 9
- RC = 76 minutes
These have only been trial fitted, and are brand new. Dimensions: 235mm x 170mm x 210mm (W x D x H - including terminals)
Terminal sizes are 20mm at the base, which tapers up at the top to about ~18mm.
5. Toyota turbo = $50
- Unkown turbo (maybe from a Supra), unknown condition. Has "46010-115F" stamped on it.
6. Nismo styled gear knob = $40
- This is brand new. Only test fitted in my car, but I don't like how it sits on the shifter. This would suit any cars with an M12 x 1.25 thread pattern. Nissan's, Toyota's, Subaru's, etc but please confirm beforehand.
7. Standard S14 fuel pump = $30
- Was working fine before being upgraded. No pics of this item as yet.
I'll only send the swaybar links, the gear knob and the fuel filter as they are small. The rest of the items are to be picked up. Located in Sydney.
All prices are negotiable. Please PM me if you have any enquiries.
Cheers!
Tuan
https://www.sau.com.au/forums/topic/274919-fs-s14s15-misc-parts/
  • 1 month later...
  • 3 weeks later...
More parts up for sale:
1. Bendix General CT Brake Pads = $30
- Model Number: DB1170
- Barely Used. Has plenty of life left in it.
- To suit s14's, s15's, skylines, 300zx's, etc etc.
2. SR20 Gaskets = $30
- Generic exhaust manifold gasket, turbo gasket, and dump gasket
Again, all prices are negotiable. Please PM me if you have any enquiries.
Cheers!
Tuan
  • 1 month later...
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
