Welshpool & O'Connor u can just rock up and have an inspection, but for East Perth, Warwick, Midland and Kelmscott you need to book.
The cops only have to find one thing wrong with your car to defect it, but then again the police do abuse their powers so your car doesnt really have to have anything wrong with it....
  • Replies 70
this ruling went out about 3 years ago
ruling is now 1.25
ie:: r32 gtr stock runs 16 x 8 equates to 16x1.25 = 20 //// 8x1.25 = 10
therefore a r32 gtr can legally now run 20x10 rims
this was explained to me by Reno the head guy at welshpool pits when i got my gtr registered with 17x9's on it
so a gtst stock is 16 by 7 so we can go to 20 by 8.75 max legally. is this right?
stock gtst rims are 6.5 i think.
Im pretty sure the constitution leaves road rules to the states? Meaning that a national code of practise isnt going to be valid unless the states have forfeited their constitutional rights to govern this?
I got that info off the state site, its quite possible its outdated, but it seems odd it would still be up if it is.
Maximum passenger car tyre and rim width
Tyres fitted to passenger cars or passenger car derivatives must not be more than 30% wider than vehicle manufacturer's widest optional tyre.
The rim width must not exceed the recommendations for the tyre fitted.
For example, if the original widest optional tyre is 185mm, the maximum tyre width is 1.3 times 185mm = 240.5mm, ie a 235mm wide tyre. The maximum rim width for a 235mm tyre is 9 inches if the aspect ratio is 60 or below.
NCOP11_Section_LS_Suspension_and_steering_3Feb2006.pdf this is downloadable from http://www.infrastructure.gov.au/roads/veh...n/vsb_ncop.aspx
Page 17 has a table to help. check it out.
Edited by StageaGirl
found it my guess is that it would be the 45 in 235*45*17
Aspect Ratio:
When buying a rim that is larger than stock, you must change the aspect ratio of the tire, too. This will keep your speedometer reading correctly. When you “upsize” your wheel, the aspect ratio will be smaller than stock. This gives your wheels and tires a wider contact patch, improving cornering ability.
Using a smaller than recommended Aspect Ratio means you have less rubber to absorb impact that can damage your rim. It also reduces the amount of contact your tires have with the road.
Using a larger than recommended Aspect Ratio increases the ride height, and will make your speedometer read slower than actual speed. It can also cause rubbing in the wheel wells. It affects steering stability, and will make your car feel floaty when cornering.
Edited by Pal
When is your car booked in at Joes Mr. Auto? I'll go to his shop and swap em over for the day :P
I'm calling him in a little while (just woke up... I'm a bit of a nightowl because I work late nights) to sort it out & I'll let you know.
I'm perfectly happy for you to grab em (I'll be dropping it as early as possible in the morning) as long as they're properly back on the car when I pick it back up :P
Don't want any of this lol
Edit: PMing you details
Edited by Psyrus
i got stickered yesterday in collie for my camber wear on my tires an they made me get my car towed back to bunbury at my cost of $250 i wasnt happy one bit,
does anyone know the rules of ride height might just take it to a dodgy garage an give em a carton :) jk
does anyone know the rules of ride height might just take it to a dodgy garage an give em a carton :laugh: jk
What is it with cops giving stickers now and saying tow the car... that is as good as a red sticker which have not been around for years and years...
I would like to know the law that says they can do this, as they are suggesting that you must now tow the car to the mechanics to get fixed and then to the pits before it is drivable...
Technically they could only make you tow it if the wear on the tyres was that bad that it would be dangerous to continue driving. How bad the camber wear is depends on that, but in this weather maybe it could have been justified....
However to do that, really the yellow sticker should be timed & dated to when they write it up, leaving no other option but to tow it, otherwise they can let you drive off again, pull you over after 20m & fine you for driving with an expired yellow sticker ~$600....
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
