up for trades or sale is my mitsubishi legnum
96 manual
dark green
88,000kms
new alternator
new battery
new hd clutch
18x7.5 work vs kf rims with near new pirelli 215/40/18 tread
tein coilovers
evo 7 recaro seat
3" cat back exhaust
fmic
front and rear strut brace
blitz pod filter
spare stocky rims
and currently uninstalled haltech interceptor piggyback ecu
in no rush to sell, just expressing interest of trades and sale
price: $18500 ono
vehicle in SA. pm or call me on 0422603195
https://www.sau.com.au/forums/topic/275305-fs-mitsubishi-legnum-with-mods/
96 manual
dark green
88,000kms
new alternator
new battery
new hd clutch
tein coilovers
evo 7 recaro seat
3" cat back exhaust
fmic
blitz pod filter
spare stocky rims
price: $18500 ono
What are you interested in trading for?
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
