Calsonic Team boss signing a shirt for me :)
Calsonic and Motul Autech team bosses signing the program for me, car #1 (last year's winner) got pole position but then had some issues before the start and had to begin the race in the pits :rofl:
p6214181.jpg p6214208.jpg p6214222.jpg p6214543.jpg p6214548.jpg p6214550.jpg p6214502.jpg p6214506.jpg p6214512.jpg
tires for the Nismo GTR and dry ice for the a/c unit :O
quickest gt400 car during qualifying
was coming 3rd when I left at 20 laps
Stands look empty :rofl: It is a shame because it is a great track for spectating, but it is a fair way from KL.
I am in Malaysia a fair bit with work and was hoping that i would get lucky and be in town when this was on...but no dice :) I adore Malaysia, great place and great people ! :O You need to post pics of the local Malaysian girls rather then the Japanese girls. LOL i am surprised that the team came with their own Japanese models ?!?!?!
hey mate
yeah not much people there as its only popular to the early 20s and 30s which I guess is good for people that were there....but queues were long today
yesterday was better with the pits and other areas
as for the girls, only a few that were malaysian.... wasnt game enough to ask the others that were just spectating as they were usually with the boyfriends/husbands ;)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
