Hi guys,
My R33 Gts-t is squealing bigtime on cold starts.
I searched the forum and found a thread on how to check the tension of the alternator belt. This diagram was posted.
Basically, when bolt 1 is completely tightened on, bolt 2 is still adjustable by hand? its not locking into place.
anyone have any ideas as to what to do from here? cheers.
https://www.sau.com.au/forums/topic/275546-r33-alternator-belt-question/
have you positively identified it as the alt belt squeal? a lot of it is starter motor pinion squeal
hey mate thanks for your response.. Yeah I'm fairly certain it is.. without sounding too noob..which I am to turbo cars.. whats the point of unlocking the first one if the second one can just be tightened or loosened by hand regardless? is the tightness of the first one the one i should be adjusting?
cheers
As noted by lachlanw, bolt (1) locks the alternator to the bracket and bolt (2) is your belt tension adjuster.
So you'd back off bolt (1) slightly, adjust the belt tension using bolt (2), then tighten bolt (1).
Then tighten bolt (2) slightly to stop it from rattling loose.
If none of this is working, I'd guess your adjuster thread is stripped.
If so you can back off bolt (1), lever the alternator out until you get correct belt tension, then tighten bolt (1).
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
