I thought that these were sold off, however after weeks of communication the seller has pulled out, which means that some other lucky SOB will get these beauties on their ride
F: 18" x 8" + 23 (Advan RS2 semi slicks, just under the markers)
R 18" x 9" +21 (Michelin Pilot Sport 2's, also under the markerS)
These are PERFECT FITMENT FOR GTST, the rears stick out about 1cm from the guard, but if you have rolled or flared guards and stretch on some 235's they look absolutely AWESOME.
The come with:
- Original Volk Black Lug Nuts w/ Lock Key
- Original Volk Centre Caps
Here are some pictures of them:
On the car:
Without tread:
With Tread:
THEY HAVE JUST BEEN RE-POLISHED, NO SCRATCHES OR GUTTER RASH
THESE RIMS ARE IN MINT CONDITION, YOU WILL NOT FIND BETTER UNLESS YOU BUY THEM BRAND NEW FOR $1,500+ A WHEEL.
PRICE: $2700 PICK UP, OR $2800 SENT VIA COURIER ANYWHERE IN AUSTRALIA.
PM ME IF YOU ARE INTERESTED, THEY ARE LOCATED IN MELBOURNE, VICTORIA.
THANKS ALL :P
https://www.sau.com.au/forums/topic/276060-18-volk-gtc-8-9/
THE PRICE IS $2700 NEGOTIABLE EVERYONE
Spoil your baby, buy her some new shoes...she will turn heads like you would not believe!!!
Just check out the first picture....these wheels definitely MAKE the car :P
https://www.sau.com.au/forums/topic/276060-18-volk-gtc-8-9/#findComment-4674442
Cheers Troy!!
I too hope that they will clear your calipers as i know you would look after these babies just as much as i did.
And he's not wrong ladies and gentlemen - these wheels will transform your car EPICLY!!
https://www.sau.com.au/forums/topic/276060-18-volk-gtc-8-9/#findComment-4675133
THESE RIMS ARE STILL FOR SALE
$2500 PICK UP FROM MELBOURNE, OR CAN COURIER TO YOUR DOOR AT YOUR EXPENSE.
COME ON GUYS, THESE RIMS ARE VERY RARE TO FIND WITH PERFECT FITMENT FOR GTST's!!!!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/276060-18-volk-gtc-8-9/#findComment-4682671
  • 3 weeks later...
  • 3 weeks later...
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
