  • Replies 174
cheers David...will let you know when it clears through mate
should be a good time out as i have enough people for individual GP if we cant get enough numbers for the enduro team event....i would prefer the team enduro thingo.....so come on boys and girls get on board
def still the 25th? if so im still in
had a bad feeling at some point in the last few days that it was the 18th LOL
Matty its on the 25th of this month mate
Need everyone's deposits in by this friday as i will be going to pay the deposit on Saturday and churn a few laps
Got some good times last sat went with a few mates as he was going back to France so did a 22.33 and a 22.35 not bad considering there were so many peanuts on the track lol
BTW David deposit cleared mate
Edited by Krishy
Cheers.
How are we going to determine teams and starting grid positions?
Well on the night i can determine the teams as to who we have present.....and the starting grid is determined by the karting place.....160 laps is a long time....
BUMP
Just a reminder that all deposits need to be in by 10th of July which happens to be this friday :laugh:
the deposit is to be paid by then and no later then that....
If i dont get enough numbers for the Enduro then the format will change to 12 drivers maximun individual GP....same price but the format will have 15 more laps lol
i would love to do an enduro though so come on people get on board
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
    • Finally back on the ground and once around the block for the first time in 2+ years
    • Ok a solution was found. I had left the factory oil temp sensor in and it was hooked up. My car never had the triple gauges.  Apparently when you delete the factory pressure and leave the temp sensor connected it triggers the oil light on the dashboard. Disconnected the temp sender, no more light.  I still haven't gotten around to look at the diagrams to figure out how/why they are tied together.
