  • Replies 174
Any chance paying on the night? as i dont know if i can make it yet.
Luke mate PM sent brew
ill hit chris (kidafa) up for this? 80$ isnt it?
when and where :D
Its $60 for 80 laps team enduro Adam
PM sent
seeing as people are now pulling out, make it individual, Mohammad.
oh and next time, lets go to pooraka! there track and karts look the goods,
hang on, ill find a link
Me, Krishy, Adrian and Scott went there on the weekend, the karts dont look a thing like the picture, and the track is alright, easiest and most fun way spend $25 in 10 minutes, legally
that track was not too bad....pitty my kart kept sliding dont think the maintenance of those karts is done very well....the chicane is awesome lol.....except jose put me into the wall bastard
well i hope your not planning on winning.... unless i miraculously loose a good 30kgs in a week...
i just dont want PubeyRS4 to win
haha, no way, im out there to have a good old thrash in an asexual way.
we should put heavy pricks like me with twigs like damo to even the teams...
that way the big boys have a chance to maybe win :banana:
lol i think we did get paired together craig.
Give this man some lolly water....coz i know you dont really drink beer Damo lol
Thats the only mentality to have at this sort of events.....if everyone is going to be all serious then where is the fun yo
The pairings will be released on the day of the event.....25th of this month yo
This is the driver pairing i did over the weekend.....just a whole mix of things
Should be a whole lot of fun.....
Krish & Mark
Ruby & Ruby +1
Vu & Lex
Anthony & David
Steve P & +1
Adrian & Dave
Damo & Craig
Andrew & Scott
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
