Wont be going after all, somethings come up
-D
Yere same with me found out we have a early b ball game thought it was a late one this week.
Can I please have a copy of the minutes as well.
Cheers
Edited by mrRS4
Yippee, i am welcomed somewhere :P....send me a sms on 0411876139 so i have ur number and can find you guys once i get there. Off street parking, i aint paying for parking, you should know by now i am a bit of a scrouge :P
So, what happened folks? Any news?
I'll have the minutes put together sometime tomorrow (busy today ... for once) and I'll also post up a summary of what was discussed shortly thereafter.
I'll email you a copy of the minutes also Martin. :laugh:
Some really good things came out of the meeting ... and its was pleasing to see more members attending. :)
To all,
My apologies for the delay. I'm an Office Manager/Bookeeper and I've naturally been flat out with the EOFY workload ... in case you haven't noticed I haven't been on here as much :down: I now have time to scratch my ass ... and will have the minutes done today and emailed off.
I've got a meeting before lunch with the Accountants to hand over the reports, then its not my problem anymore. The office will be empty this afternoon, which means plenty of time to put my feet up and get onto finishing those minutes with ease.
Thanks for your patience.
Nene, I will be right onto your requests today ... pronto!
Ruby
:D
So ... you're giving me free IQ for the EOFY bullshit I gotta do Damo? :wub:
Noice!
Meeting minutes have been emailed. If I missed anyone, PM me your email addy.
:P
Ruby I've been meaning to join up but I will only do it on one condition - that you change your avatar. I'm sooooooooo sick of having to see a male groin thrust in my face. Use scandy's avatar as an example of what I'd prefer to see.
I wouldn't be able to attend Monday meetings as I play indoor soccer on Monday nights.
Edited by writeoff
