Having a clean out of the shed at the moment, the following new parts have to go.
Jaycar Kits
KC-5387 Independent Electronic Boost Controller kit - RRP $79.95 - More info here.
KC-5385 Digital Fuel Adjuster kit - RRP $84.95 - More info here.
KC-5386 Hand Controller kit for IEBC/DFA - RRP $67.95 - More info here.
WC-7502 D25 connecting cable - RRP $13.95.
Total RRP $246.80 - will sell as a bundle for $150.
Sydneykid and a few others have fitted these kits, do a search in the Tech forums for more info if you're not sure how/if they will work on your car.
Also have a KLS Short Shifter kit for R33 GTS-T still in the box, with genuine Nissan nylon bush and longer hex head bolts, to replace the shorter versions included in these kits.
Cost $100 without the genuine bush and longer bolts - will sell for $70.
Shoot me a PM if you want any more info, these are cheap so first in best dressed :(
  • 3 months later...
