a good amp can make a cheap sub sing compared to a lesser amp.
a shit amp driving the worlds most expensive sub will always sound crap.
Budget first, rest will follow.
budget for a "budget" system should along the lines of;
Front Stage $300
Sub $200
Amp $500
double all those numbers and you've got my own system budget :P
if you haven't got $1000 to spend, don't look at amps and subs IMHO. the $100 or so cable costs would likely scare you off too.
well, indeed.
I find most people who want to do a "cheap" system don't even consider the cost of cabling at all!
$100 would cover shit cabling for a very limited system.
I just re-looked at my system list from two years ago;
Deck - $450 ($699 RRP now)
front stage - $560 ($899 RRP now)
sub - $350 ($469 RRP now)
amp - $560 ($999 RRP now) - fark me that was a bargain :sick:
Dynamatt - $290 ($350 RRP)
Cables - $194 (RRP probably double!)
Custom Enclosure - $259
it's basic in terms of complexity, but installed well with GOOD components.
my system is pretty balanced with good SQ and not outrages in terms of install - apart from the boot and the deck, you wouldn't know it wasn't stock until you turn it on.
also shows how easy it is to spend $4K in audio :)
They don't usually include installation either...
Once you deduct all of the extras the budget for gear gets even smaller :rofl:
to install all the gear above took me about 16hrs all up. Dynamatt alone was about a third!
a pro would be half that - with a help, but that is still approaching $700-$1000 to do the work!
You don't need to spend hundreds on cables, read mobileelectronics Australia about the cables arguments if you still think there is a difference in the cable.
A good cheapish amp is probably something from the Jaycar store, but have a look on mobileelectronics Australia.
for power and speaker cable all you are paying for is flexibility. ie: softer cables that are easier to work with. cause yes, copper is copper. but 4gauge power is like $10 a metre even for jaycar stuff. you'd struggle to use less than 5m in any install, 1m amp neg, 1m batt neg, 3m +ve amp - so there is $50 right there before you even start. Half the cost if you go for 8ga, which is what most people need really.
you then need 4 ring terminals ($3 ea for crimps) and two spade (ditto), a fuse holder ($15 round, $25 blade) and fuse ($5 round, $10 blade) $40-50 here.
now add 15m of flexi speaker cable for splits, and a few metres of some thick stuff for the sub - $40 easy, even for cheap stuff
then, RCA's - now this is where quality can make a difference, not silly $200 RCA's but it is worth spending at least $20 on a decent pair of shielded RCA's, jaycar 2m ones are $18 - you'll need 2 pair in even a modest install.
thats $150 for a single amp, 5 speaker setup (mids, tweeters and one sub)
it adds up - even for cheap stuff!
i couldn't hear much difference between $30 cables and $250 audision ones.
i guess it all comes down to how much money one has to spend
it all comes down to noise really.
you might not hear the difference between $10 and $200 cables, but spending $50 instead of $10 might be the difference between a noisy system.
speaker and power - copper is copper pretty much.
Okay, to answer the threads original question.
I sell packages where i work, which consist of:
1x KFC-3514DVC Kenwood 12" 400wrms Dual 4 Ohm Sub
1x KAC-8104D Kenwood Mono Amplifier 500wrms @ 2 Ohms
1x 500w 8ga Wiring Kit
1x Aerpro 12" Box
Usually RRP for about 500-600, i sold the last few for about $450.
Nice sounding entry level sub, they unfortunately dont manufacture them anymore, so a great time to buy as most stores are clearing their stock. I had a pair handle over 600wrms each continously in a customers car for over 2 years now, he gives it an absolute hiding, still going.
Stick with brands that have had a mainstream following for over 20 years, IE: Pioneer, Alpine, Kenwood, Sony, JVC, Clarion. As long as you correctly size your amplifiers accordingly with your woofer, you should be happy, and in the event that you aren't, they'll usually help out.
Steer clear of cheap imported rubbish, gear that is made to satisfy a price point only, bargain bin buying (unless its a good brand), buying from ebay, or buying a brand you have never heard of. If its only been around for 5 years its probably a good idea to research it properly first. If it claims to make 1000WRMS for $400, be very sceptical, check the voltage and THD at which their claim was made, and always pay attention to the CEA rating.
if installed properly there will be zero noise even with $10 cables .
1x Aerpro 12" Box
excellent advice :up:
I've seen some pretty shit cables. like, completely unshielded ones where it didn't matter where they were run they picked up noise, even from tiny factory power to things like interior lights. a set of $20 Jaycar ones solved the issue.
one rule of thumb with rca leads.
black and thin, throw them in the bin. they may work fine for home audio, but a car is full of noise and cheap rcas will let down your whole system.
as long as you pick up a decent rca lead like an aerpro double shielded set, you'll be fine. you need to spend accordingly on your system, as long as you pick some that are about 60 for the whole wiring kit, you'll be fine. just dont run the power and the rca leads together (including the remote signal).
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
