Ha never thought of that, Ill hit you up in a week. :) any engine bay pics? , sounds pretty sexual .
Will do after the weekend. I would have gone the Jun route, but i had a Greddy style and nothing to do with it (was initially for an S13 with an RB30DET, as the stock plenum didnt clear the bonnet, but went R32 head instead).
Mine was <$500 for the plenum and 80mm billet TB, almost half what the JUN style inc TB's cost, not sure how much performance difference there would be, but the JUN is definately more ideally suited for N/A due to the bellmouth's, longer and identical length intake runners.
I had a look on a plenum calculator, and for peak volumetric efficiency at 6000rpm i need 12" intake runners with a 2" diameter - somthing ill make at somepoint, until then the greddy should keep me happy. Mainly wanted it for the larger TB, and to get the intake away from the hotside of the engine, as well as the benefit from a much shorter intake pipe to CAI. Not sure what it will do for VE gain, as i think the runners may be too short, time will tell :blink:.
ECU is microtech LT12S, GTR loom, 550cc injectors (low duty cycle for better efficiency taking advantage of the sequential injection) fujitsumoto jasma tuned length extractors, 3" mandrel exhaust (1 centre offset mandrel glass packed perforated muffler, straight through resonator, no cat) 1.5mm gap 7 heat range plugs, upgraded coilpacks, 255, 8.3deg cams & >11.5:1 compression ratio.
once its together, should be quite angry. Had this in the works for a while, but i got distracted with yet another car (30e+t) made some big numbers with it, got bored, its done now so i'm back to my N/A ways on this old project.
https://www.sau.com.au/forums/topic/276959-rb25de/#findComment-4688111
  • 1 month later...
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
