  • Replies 81
Posted Images
No I did not. I haven't touched any springs/shocks on my car since it arrived from Japan.
Aren't coupe always a little bit lower than sedans?
going from 245/45R18 to 275/35R19 does reduce the diameter by about 2.5mm which is not really much, and reduce the rolling diameter by about 8 mm only.
maybe the car had 350Z spring or a lowered spring, but the ride felt stock - no sign of aftermarket spring feel when it was on its OEM 18" a while ago. On 19" with lower profile it does introduce a bit more harshness because of the smaller sidewall...
It's also a very tidy auto so very unlikely the previous owner modified it in Japan with coilovers etc.
What is the correct size for rims + tyres for 19" on the Coupe?
Do a bit of research on g35driver.com plenty of info there.
Coupes can take a much wider wheel/tire combo front and back not to mention run really low offsets as well. You should take full advantage of this if you have a coupe. My advice:
1. find the wheel that you like
2. see if they are available in 9" front and 10" rear
3. choose an offset between +10 to +15
4. Then use the tire calculator to work out tyre profile and width
If you are looking locally at wheel shops etc, your choices will be significantly limited with regards to offset and width.
Try sourcing 2nd hand Jap wheels, there are quite a few around if you keep your eyes peeled.
Ok, been looking around.
If i decide to go from 225/40/18f to 245/35/19f, then i actually lower the ride height by about 40mm? Is that right?
They are both completely wrong profiles for a V35.
Use the calculator and stick in 245/45/18 as your tyre then compare it with profiles in 19 inch.
To give you an idea I'm running 245/40/19 and 275/35/19. Your overall diameter should be around 675mm on average +/1 15mm is ok
sorry n1sm0, 245/40/19 is the WRONG profile for V35 front.
the closest profile to stock 225/45/18 at the front is 245/35/19
the rear 275/35/19 you have IS the closest profile to stock 245/45/18
245/40/19 = 678mm
275/35/19 = 674mm
245/45/18 = 677mm
Don't argue with me :( I've done my homework, my tire guys agree with me and the guys in the US run this profile on their g35s :)
Our cars are rear wheel drive, best to compare it with the rears.
The guys on the G35 forums are saying the closest to stock is 245/35/19f and 275/35/19r but not on OEM 19" rims, only on rims that are at least 9"....
That's why i was wondering if i went from 225/40/18 (my current incorrect tyre) at the front, and wanted to get a 19" wheel+rim, then apparently the correct is 245/35/19f and 275/35/19r, and my question was - this actually lowers the ride height?
Edited by Eldubb
it won't lower ur ride height, it will give u increased ground clearance.
Rianto - the 225/45/18 & 245/45/18 combo is a bit of an exception to the rule, difference in OD is quite a fair bit and the 350zs came with these from factory, so I understand where you are coming from. But remember, our cars (sedan) came out of the factory with all 4 same width wheels and tyre profiles, so it would make sense to keep the OD front and rear as close as possible.
There are guys in the US tht run 245/35/19 & 275/30/19..they are the ones who dump their cars and like running skinny tires which looks good.
yep, but that's because the guy who's asking this question wants a 19" for his coupe, that's why I was referring to the staggered coupe sizes...
and very unlikely he's going for a standard OEM 19" from late model V35...
V35 coupe also come with this size from factory, exactly like 350Z, despite both 18" rims has 8" wide front and back... don't ask me why, I think Nissan should have made the front ones 7" or 7.5" as it shown on my OEM rims the 8" wide with skinny 225 tyre at the front caused the previous owner in Japan scratch the rims badly on japanese gutter.
My 18" have also bad gutter rash from japan because of this. so we all agree if i go 19 x 9, i'll try to get the 245/35 front and 275/35 back?
Edited by Eldubb
Hey Eldubb,
I'm looking at exactly the same issue too. So did you buy the 19" at 245/35f and 275/35r?
Also for the guys that know, the offsets that are supposed to best suit the V35 are in the teens, i.e. +15.
The guys at the tyre shop were offering me +30's offset, what is the difference? How will it affect the ride?
In terms of rim, they have Work wheels, which are beautiful, but a little pricey of course.
They also have Taiwanese made wheels, which look great, but a lot heavier and cheaper, what do you guys think?
Standard offset on V35 coupe is +30 front and back...
My aftermarket is +30 front and +25 rear. There is no need to go to +15... the more the difference in offset that can cause more strain to the hub, causing premature wear on hub bearings....
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
