Hi everyone. Need quick cash for an engine, got to get my 180 back on the road!
For quick sale I have!
Two sr20 red top heads in great condition
They come with valves and valve springs
Sr20 red top head bits such as rocker arms etc etc
Sr20 red top standard camshafts
in great condition
Sr20 red top GREDDY EASY aftermarket camshafts
intake cam has been damaged on one lobe due to rocker arm coming out
and another lobe looks like it has been run dry of oil for a bit
will need repairing otherwise great condition
Sr20 red top bottom end
turns fine detonated piston two needs easy rebuild
comes chain and all those other bits
seized engine needs complete rebuild
Apexi Power FC DJetro Red Top
Comes complete with sensors and wiring
Two sr20 red top intake manifolds
Sr20 red top turbo and exhaust manifold with dump pipe with turbo lines
Sr20 air condenser
Sr20 alternator
Sr20 water pump
Sr20 standard clutch and flywheel
Sr20 standard clutch slave cylinder
180sx standard rear lights
180sx standard front lights
globe casing only
D1 spec earth kit
180sx s13 front and rear hubs with disks
S14, S15 brake pads standard front and rear
S13 side pillars
S13 vents
S13 sun visors
Silvia steering rack
Dash cluster 100000kms taco doesn't work
Indicator and washer switches
Center console
Rocker covers "engine covers"
Two sets of coil packs with loom etc
Standard catalytic converter
Power steering pump
After anything just ask I may just have it :)
Offer me prices guys but don't try to rip me off hectic
Located in NSW Wollongong Australia
Will post worldwide if buyer will pay
Prefer txt or email
0423428670 [email protected]
Here are some pictures Im not willing to take anymore as the parts
are neatly and carefully stored under the house
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
