Hey people,
Little bit of background...I recently sold my 300rwkW JZA70 Supra to start saving for a house deposit...that is until I found this and bought it, lol.
The biggest factor in buying it was the motor and clearly not the cosmetics as you will see.
- Fully rebuilt motor, bored to 2.7L with forged internals, crack tested and strengthened crank, new bearings / seals / gaskets etc.
- Rebuilt head, no porting but replaced valves and recut seats etc
- 18x10 +18 Work Emotion XD9's all round with stretched shitty Wanli 235/40 tyres
- Some kind of exhaust
- What I think is a HKS intercooler
- Tein coilovers of some kind
- Custom paint :(
Currently makes somewhere in the vicinity of 250awkW with stock ecu and stock R33 GTR turbos. If I could get some traction and turn in it would be an insanely quick car!
Needs:
* More low
* More wide tyres
* Less misfire
* More fast
* More twin 2560's
Regards,
Jon
https://www.sau.com.au/forums/topic/277362-r32-gtr/
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
