Nice pics mate!
Maybe try some panning shots next time too! Good captures.
Thanks. I tried some panning shots, but the slowest pan speed i could go was about 1/80 before it becomes too blurry, so I pretty much stuck with that the whole day. Still need to prac panning.
Saw your site as well. Just wondering, what lens and speeds were the pans taken at?
1/80 should be low as you should go..
ideally anywhere between 1/100-1/250 will be good.. You should have got some great panning shots with 1/80.. Post up some samples perhaps?
The ones I had posted up are at 1/100 or 1/80. I think the lack of pan-blur was because the corner I was on was a hairpin so they were coming towards me, rather than a side on shot. The variations in blue were also due to a polariser
Thanks for browsing my site champ!
All shots were taken with a Canon 50D and a Canon 300 2.8L IS with a 1.4xTC stuck on them for most of them. At the SAU track day, panning shots were taken at 1/40th-1/80th and at BMW Super Sprint the shots varied again, between 1/30th-1/60th. Cars were going around 100-150 km/h.
Reason i went lower was for more blur as well as more wheel motion blur. You are correct on saying that the hairpin is probably why you don't have so much blur because they were moving a bit slower.
SAU was taken at Oran Park GP and BMW was at wakefield.
With more practice you will definately get better, if this is your first attempt at panning then you have excelled! If your finding it hard to get good pans due to harsh lighting, use either a polarizer or an ND (Neutral Density) filter, or open up your aperture to lower your Shutter speed. You may need to stack or use a higher grade of ND filter to get the preferred shutter speed.
Your last shot of the Astra seems really flat and "blue-ish". Is this an edit or incorrect white balance?
Post up more shots mate :)
Edited by FST513
Thanks, first time ever at a track.
I normally have it set to auto white balance and my pshop skills arent very good. Might have been the whiteness of the astra messing with the AWB?
Also used a B+W polariser, so as I was twisting on the spot, frontal and back end shots would have looked a little different.
I'm looking at getting an ND filter and the Canon TC but am really short on cash atm lol.
Heres a few more from the day http://www.flickr.com/photos/tenchi12/sets...57620769855882/
This one was taken at 400mm from the stands. Cropped and one of the few decent shots at the start of the day from the stands
Some three wheel action of my friend's Swift...right before he spun out
Some more three wheel action on a Civic
No three action from the Evo though
A chillin' Zed
Edited by Tenchi12
Shot with a 400mm? You got a 400 2.8! Awesome. Unless you mean you have a 100-400 or something. Yeah i corrected that astra in photoshop for correct white balance, but it just seems like it was "flat" out of the camera. I donno, could be many things, but its just the one single photo..
Great pics by the way mate, good first attempt!
Heh nah shot with a 100-400mm. Not rich enough for a 400 2.8. One day though...maybe even a 600mm. Btw let me know if you go to another motorsports event so I can tag along xD
No problem mate :P
Pretty sure i will be heading out to the "Texikhana" SAU is holding on the 29th August (IF i'm not in NZ snowboarding) i think a few other 'togs are going as well, should be a good day. I might also be going to Circuit Clubs wakefield day on the 25th of July at wakefield. I will let you know :)
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
