FOR SALE: Nokia E71
Mum just bought this on her plan but im after a different phone so its up for sale at $450
these retail at $500 brand new, like i said it is unopened and still intransit from Optus to us so its in shrink wrap and all.
Cheers guys PM me
Piccies: you know what they look like. unless you want to know what a box shrink wrapped looks like then FINE il put it up lol
Edited by GODGIKO
https://www.sau.com.au/forums/topic/277560-brand-new-unopened-nokia-e71/
Another thing to keep in mind mate:
"> All phones we sold are overseas stock and never locked. All phones support PREPAID and POSTPAID Telstra, Optus, Vodafone, Soul and Virgin mobile customer."
I'd never buy a good phone off ebay... some cheapo second hander sure, but not a nice one. If any issues you need to send it overseas to get fixed.
Trust me, i just bought this phone brand new unlocked from Vodafone 1 month ago for $600, $450 is a top price.
Actually, in law, you have rights against the seller, and the manufacturer.
They provide 1 year warranty, you send it back to them, not overseas.
Furthermore, you pay with paypal over ebay which gives you the opption to launch a claim within 45 days should something bad happen.
You are very protected buying from ebay :P
This low is joke anyway ,
Refunds by law: In Australia, consumers have a legal right to obtain a refund from a business for goods purchased (but not at auction) if the goods are faulty, not fit for purpose or don't match description.
Ebay is auction ? is in it ?
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
