Hi guys as stated above, its a black R33 SII with sunroof, this is very rare to find.
im the first owner in oz. Car has done 125xxx km.
- Front mount
- Full Xforce 3" exhaust
- Apexi pod filter
- Boost gauge
- 12 dis cd stacker.
- 18X8 front and 18X9 rear
- Front and rear strut bar
- Lowered spring
car has always been running on 98 octane and service every 5k kms
$13k
0433 313 342
Edited by Tee-CnC
https://www.sau.com.au/forums/topic/277561-r33-sii-with-sunroof/
Ive seen your car on carsales. Would you go any lower?
Any interior pics etc
Hi Danno, pics of interior will be post up very soon when i get the chance to. But it i can tell you now that its
standard and in perfect condition.
as for price u can call me or pm me for detail.
Cheers
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
