Hi guys can someone explain to me how having a BOV vented to the atmosphere increases pollution? No not noise, that isn't the issue, unless it's over the DBA limit of course. The BOV only opens when the throttle is closed and when the throttle is closed the PCV valve draws air from the cam cover venting into the engine where it is combusted and cleaned by the cat.
So if everything is working OK, the only thing that comes out of the BOV is what went through the air filter. Since the air filter cleans out some crap, I would have thought the EPA would be happy with BOV's vented to atmosphere as they clean up the air for us to breath.
Try that next time the pesky pests annoy you.
https://www.sau.com.au/forums/topic/2776-bovs/page/2/#findComment-309431
Yeah but that assumes your engine and BOV are in perfect running order. I would imagine there would be a number of incidences where a sick engine/turbo can spew noxious gases out of the BOV. Also would a venting BOV make the engine run rich? Changing these circumstances would increase noxious emissions?
T.
https://www.sau.com.au/forums/topic/2776-bovs/page/2/#findComment-309632
Hi Tony, a couple of comments following on from your last post.....
"assumes your engine and BOV are in perfect running order"
So the pesky pests should be checking badly running cars, not ones with atmosphere vented BOV's. I followed a car to work this monring that was spewing so bad I had tears in my eyes, had to put the A/C on recirc.
"Also would a venting BOV make the engine run rich"
Yep, but not as much as when the engine is cold. At least the cat will be warmed up when the BOV vents and do something about it. When the engine is rich and cold, so is the cat, so it don't do squat.
Hope that adds to the discussion.
https://www.sau.com.au/forums/topic/2776-bovs/page/2/#findComment-311297
Can you make all BOV's plumbback, or only specially designed ones?
i am not a riceboy but dont have a big adversion to the noise as long as it only comes on when boosting.
But i dont really want a atmo venting one as i couldnt be bothered with the hassle from the cops
yes i will be running large amounts of boost on occasion :D
https://www.sau.com.au/forums/topic/2776-bovs/page/2/#findComment-313070
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
