My old man is selling the Turbo PRB Clubman, wants to retire and go fishing.
Details:
PRB Clubman Build #47
4AGZE Turbo Motor
Supra Gear Box
Sprinter Diff Kazz LSD
Motec with traction control
Here is some more info and history written by my old man.
PRB047 has twice won outright the NSW Super Sprint Championship. Once on Dunlop slicks in 2007 in type 4E and once on Kumho V700 tyres in type SVC in 2008. It holds the NSW type SV Super Sprint lap record at Eastern Creek with a time of 1 minute 42.56 seconds, see Natsoft 17th May 2009.
I bought PRB047 in 1994 from PRB Australia and built it with a standard 4AGE motor and computer, through PRB Australia it was registered as an Australian built low volume production vehicle.
In this form I super sprinted, and later, as my two sons came of age, they enjoyed their introduction to motor sport.
I progressed to the Clubman Challenge and the 6 hour relay race, hence the large petrol tank.
In 1999 I fitted a 1600cc race motor and run this for a few years, finding that the race motor changed the character of the car, making it unpleasant to drive on the road and also finding that I could not keep up with the stroker motors, I decided to build a turbo motor.
I have developed the turbo motor over the past six years to make it what is today, a super reliable and quiet package that has the power of the stroker motors but not their bad road manners.
One of my most satisfying accomplishments is to have overcome the common turbo motors surge of power problem that spins you out when pulling out of corners, by fitting the Motec traction control system, the car now drive like a naturally aspirated vehicle.
Now I think its time for me to take a step back from the super sprint front runners and try and develop another hobby that can take me into retirement.
Full specifications supplied on request.
This vehicle is set up for track work but can be driven like a normal car on the road, should the new owner not wish to use full power until he is comfortable with the car, then it is just a matter of unplugging the Motec boost controller which will reduce the boost to 7psi. The car will then drive like a non-turbo 20 valve PRB
Price $37,500
Please pm me for contact number or email me at [email protected]
https://www.sau.com.au/forums/topic/279438-prb-clubman-turbo-37500/
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
