As per topic,
Comes with used Emanage Piggy back ECU, along with main wiring harness and extra harness.
Local pickup available, extra $15 for interstate shipping.
Price: $350
Contact: PM me
Reason: No longer required
What is an E-Manage? What can an E-Manage do? An E-Manage belongs to the category of electronics called piggyback controllers. They are called this because the do not completely replace the factory engine management unit, but rather work in conjunction with the factory unit to allow you to tune and control specific aspects of the engine's operation while allowing the the original to maintain control of the rest. It is the best of both worlds!
Today's engine management unit is an incredibly complex piece of machinery. It does far more than simply control the delivery of fuel and ignition to the engine. They also control valve timing and are responsible for adjusting emissions. Nearly every piece of electronic equipment in the car ties its operation into the ECU. You can't simply yank it out and expect the car to operate correctly.
Fortunately, there is hope for the auto enthusiast who needs to extract more performance from his or her car than the stock ECU was intended to provide. That hope is the GReddy EManage. This precision controller will allow you to adjust a broad range of performance-related controls in concert with the ECU. The result? Killer performance and a car the works properly, as the manufacturer intended.
Consider just a few of the things you can control with your GReddy EManage:
Fuel Delivery - Compensate for upgraded mass air flow meters, throttle bodies, or fuel injectors.
* Adjustment of fuel delivery at 5 different RPM ranges
* Adjustment of air flow meter signal by up to 20%
* Incorporated Fuel- and Boost-Cut Controller
* Control of up to two additional injectors activated by boost or RPM level (with optional boost sensor)
* Idle adjustment circuit included
Ignition Timing Adjustment - Control your ignition timing under high-output conditions (with optional timing adjustment harness)
VTEC Timing - Have one of these in your car? Now you can do even more!
* Set valve timing based on Engine Speed
* Use your factory non-VTEC ECU with your VTEC engine swap!
https://www.sau.com.au/forums/topic/279874-fs-greddy-emanage-blue/
  • 4 weeks later...
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
