Hi there, I want to use bonnet pins to secure my bonnet so that I can get rid of the latch support bracket from the front of my car. I would like to use standrad-type bonnet pins as I like the look of them; though I am concerned that people will be able to open my bonnet if I use these and remove the standard latch.
Is there a way to lock a bonnet using standard pins? I was thinking of using a pad-lock like you would use on your luggage though that is pretty daggy. I am aware that you can get lcokable latches from Aerocatch (http://www.aerocatch.com/) though I prefer the look of a normal pin.
Any help or ideas would be great - thanks!
Mate, why would you want to remove the front latch? I hope you realise that the bonnet pins are just what they are called "pins." In other words, the only thing hold down your bonnet is two thine metal rods. If you're going on the freeway and doing 100 km/h place, I would be worried if the front latch is not there...keep both...
However, there are lockable mechanisms out there where you can actually lock the bonnet from the inside - underneath the bonnet, it's controlled by an electronic mechanism. The question is, why go through all this?
Good luck.
Here's a picture of one GTR that has done heaps of driving at 100 km plus and uses bonnet pins to hold the bonnet down with-out the factory latch : )
I am going through a bit of an effort where I am trying to get all 'non essential' bits out of my engine bay because
a. I think it looks cool
b. I am constantly fixing things and having less things means that there are less things to fix
c. I think it looks cool
I agree that the electronic latch thing seems a bit too hard to bother and perhaps the Aerolatch is the way to go; though I am interested in other ideas if people have them. Thanks.
Hey mate, fair enough...just make sure you buy the good genuine bonnet pins not the cheapo Chinese made ones as if those rods breaks, you know what happens... I've seen way too many cracked windscreens/bonnets to fear... I got both the latch and bonnet pins just to be sure.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
