Well, at moment no one else has steel BB or the rights to make steel bearing BB turbos apart from Garrett them selves. So there is nothing to really compare to.
In sleeve bearings turbos, Materials in Garrett Bearings and seals are lot harder (which we use).
for the rest bits Depends on who you compare it with. If its compare against Mallet or Turbo International (we also use) there isn't much of difference.
If Compare to some cheap ChinaChargers you will notice lot of difference in shaft tolerance, Bearing tolerance, weight tolerance and Material components.
https://www.sau.com.au/forums/topic/280862-gt3076r/#findComment-4737119
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
