ok,
this is probably a really stupid question, but i was wondering the best way to rip a fat burnout in a manual.
Auto V8's are easy... doesnt take a brain surgeon to work that one out... but i want to be able to rip a fat burnout in a manual, without shifting off the original line.. any suggestions.
i have found a few different ways, but none are perfect and most the tail likes to step sideways a bit when im doing it...
dave ;)
https://www.sau.com.au/forums/topic/28109-burnouts-d/
I'm going to assume that this question is in regards to burnouts when warming tyres at a legal drag meet.
1. Push clutch in
2. Select a gear (1st is simple but 2nd warms up better)
3. Build up the revs to a nice high rpm. I recommend 8,000.
4. Drop the clutch and quickly move foot from clutch to brake.
5. Heat till satisfied.
6. Serve hot.
;):D:D:D:D:D:D
It's difficult to stop the back from sliding out, but it's something you just need to live with ;)
https://www.sau.com.au/forums/topic/28109-burnouts-d/#findComment-585363
lol... the colt.
OR... adding to leewah (which is by far the easiest and most effective)
You can use heel/toe.
Use your toe to build up revs... then put down the brake... then bring off the clutch.
It's just easier to do leewahs ;)
https://www.sau.com.au/forums/topic/28109-burnouts-d/#findComment-585448
I know what leewah has - but the person asking the question doesnt have what leewah has - get it?
Telling someone to launch at 8000 revs when their car doesnt go that far [from factory] doesnt make sense...
anyway who cares - I have a STAR ;) !!!
https://www.sau.com.au/forums/topic/28109-burnouts-d/#findComment-585719
oh also, when you do this at the drags, how much tire tread does it take off... cos i reckon i took about half the tread off these brand new (3000km) tires in 4 or 5 burnouts.
Thanks - just wanting to know so when i get back to melb i can push the liner into a high 13 for my first ever official drag.
https://www.sau.com.au/forums/topic/28109-burnouts-d/#findComment-585898
anyway who cares - I have a STAR :P !!!
my 33 hits 8000rpm (rev limit set at 8500 for some reason) but i dont think i will go that far.. in my pissy 205 tires i only need to dial up 4k..
now getting a v8 up to 8k and dropping , that could be fun.. thats about 3000rpm over the red line :P
https://www.sau.com.au/forums/topic/28109-burnouts-d/#findComment-585908
ok im back in here - for a minute.
I still dont think its reasonable to advise people to launch at 8,000rpm - thats my point, always has been my point. And 8,000 rpm wont be necessary or possible on the average "forum user's" car!
As I said, mine will do burnouts easily launching from 3,000 - 5,000rpm so why bother with maxing your revs out just on launch? Its going to climb up to the max rpm very quickly in 1st or 2nd anyway...
Dave I think I can safely assume you are not in the category of having:
A: A GTR
B: An RB26
C: A Worked RB26
D: A Huge Aftermarket Turbo hanging off an RB26
E: A 700HP+ engine
Maybe I am wrong. This type of setup probably does need much higher revs than your average liner to invoke wheelspin, though I am sure its fun!
My main point is I think YOUR original question [the reason we are in this thread] wasnt answered effectively, thus I tried to help. I also think a lot of other forum goes will be looking in here and trying to learn from the Q&A's
/end rant
HKSgtst - hover your cursor over the star and some magic will happen :( Works differently depending on star colour ;)
https://www.sau.com.au/forums/topic/28109-burnouts-d/#findComment-586705
