hi there i have a set of rays wheels for sale 5 x 114.3. they are 17 x8 and 17 x9. have been used on a circuit car and have now been sitting around for a while. they do look better then the photos but are second hand so remebr that. still a good looking wheel though and not that heavy. check out the pics.price is 600 ono no tyres or for 700 ono with a set 0f 235 40 17 inch toyo r888's that have a few track days left in  them and are worth it alone. email me.
also have a set i bought of r32 sumitomo 4 piston calipers was going to use on a circuit car but never did. they are as i bought them except i have machined off the nissan logo so that they wouldve fit under the wheels. 200 or ono. email me at [email protected] or pm me.
cheers
https://www.sau.com.au/forums/topic/281522-fs-wheels-and-brake-calipers/
whats the offset on these wheels and do u have pics of them on an agle on the car? thanks
the offsets ill have to get back to you on monday as ill have to doublecheck.  i have many many pics of these wheels on my car so no prob. heres one on an angle. they are a deep dish design. obviously the rear 9 inch is a deeper dish then the front 8 inch, however even the 8 inch still looks deep. ill also doublecheck what the name or model of the wheels are. only reason why i am upgrading by the way is because im going to 17 x 10s all round, otherwise i really do love these wheels.
ok the offsets are 17 by 8 inch +34 and 17 by 9 inch +37.
and have also got a few quotes on shipping and for example if i were to ship to sydney without tyres in a box as 4 seperate parcels. australia post 25 dollars each, so 100 all up. not bad price.
hi, is that 25 each wihtout the tyres? also, have they been redrilled to suit the gtv6?
yes that is 25 each without the tyres. no, they have not been redrilled at all, infact my gtv6 hubs have been redrilled to suit he 114.3 stud pattern. oh and forgot to mention earler it sees like they are a multi fit 5 and 4 stud wheels. ive never actually realied till i had a closer look.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
