Hey Guys,
I have sitting in my yard (needing a home),
r32 GTR half-cut, engine (done 73xxxkms, compression check of ~158 across all six, welcome to come and test yourself's), gearbox, twin plate clutch, ECU and loom, dash, instruments.
Welcome to come and inspect.
Chasing $6000 for complete half cut.
Also have complete rear end for GTR R32. Cradle, diff, hubs, axles, brakes.
Chasing $1100 complete.
Front complete knuckles $300 the pair.
Front LCA $400 the pair.
Front axles $150 the pair.
Front radius/castor arms $250 the pair. (Adjustable's)
Front upper camber arms $300 the pair. (Adjustable's)
Few other bits and pieces. Located in The Gap, Brisbane, QLD.
Please don't hesitate to call me on 0431657139 Jason
https://www.sau.com.au/forums/topic/281739-r32-rb26dett-gtr-half-cut/
3K for the whole lot mate
jesus there's some orportunistic types out there.
Try to get a front cut from the importers now, with the exchange rates they are not bringing in any stock, and when they do???, it's selling for 6k plus, and it tired and old and worn.
Try Joe at SSS automotive in Sydney, that's a bit closer to you in Melbourne I'd say
Im selling a r32 gtr front cut here in Brisnabane ( sorry to hijack buddy) I reckon 6k is pretty fair, and I'm negotiable too, but not for anal rape
You could just go and buy a whole r32 gtr car for like 10k if you can find one????
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
