hey guys and girls
i have some stuff im ken to get rid of . can post all items!
GTR 33 Boost solonoid ( good for making your own electric boost controller and replacign faulty one) $45
Power FC boost control solanoid ( jsut wire to the side of your power FC) $160
R32 GTST projector headlights, Immaculate condition $ 100 pair
Japanese 3 stage Bleed valve, has 3 selligs by turning a knob! Cheap Cheap $ 20 bux
Standard R32 GTST turbo , usual small shaft play, works very well with actuator, dump, and elbow $70
BRAND new Bosch o2 sensor, never used rrp is 250 for this bad boy .. $ 45
Brand new bendix rear pads for R32 skyline TYPE M! $40
Weds speed star Vienna wheels, ( same as VsKF) 18x9 +23 ( with shnider included), they have good Bridgestone Re-01R tires 225/40/18 and are IMMACUALTE condition , $ 650 PAIR ONLY. in the attached picture they are the front wheels!
Also R32 GTST 4 door , ALL the fruit , check my topics $11,000!!! the 1 in the pic!
EVERYTHING IN ADELAIDE!
Edited by 5LTBETR
  • 4 weeks later...
Mate,
Can you please PM me your address so I can take the Rb26 boost solenoid off your hands?
P.s. Make it an even $40 as I can't take $5 out of the ATM aha :laugh:
Wayne.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
