hey all, just needing to clear some parts out to make room for new parts coming in
Located: Sydney
Contact: via PM is best
MRT catback GC8 exhaust in mild steel with SS axle back- 400
Enkie NT03 17x8 +32 17x9 +15 set in excellent cond freshly powdercoated in matte white- 1100
skyline (suit silvia with mod to 1 hole) Bride superlow side mount rails- 200
Stock r33 gtst injectors set of 6 great working order- 100
Custom dump pipe + rewelded split screamer for internal gate suit 33 turbo rear housing. 6 bolt i think it was- 250
r33 std f/r swaybars- 50ea
r33 std hicas- 50
Keep an eye out with more parts to come and pics will b uploaded shortly
Cheerio
Dom
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
