  • Replies 43
Short answer: BAD...
Don't do it!!
BOV is there for a reason. To allow the pressurised air to NOT hit back onto the turbo compressor wheel. Over time it may cause damage to the fins.
Why on earth would you want the "flutter sound" anyway?? I hope it’s not to sound "cool" :banana:
https://www.sau.com.au/forums/topic/282464-flutterdumpdose/#findComment-4756251
Lol, this topic again?
50% of the world will say its bad, the other 50% will say it isnt. Personally i think it sounds awesome, but at the same time i fully agree with Adam, i dont see how it cant be bad for the turbo. Its compressor surge, spinning the turbine backwards, it can not be good. If you didnt need a BOV, why would anyone have them?
https://www.sau.com.au/forums/topic/282464-flutterdumpdose/#findComment-4756421
The sound of flutter/dose is awesome. Love it.
It will kill a ceramic turbo like stock R32, R33, R34, S13-S15 turbo's. Won't kill steel turbo's like single VG30 turbo's or RB30ET turbo's.
Flutter at 10psi is ok, but if you are running 14+ psi through a RB20/25 turbo it will kill the turbo
https://www.sau.com.au/forums/topic/282464-flutterdumpdose/#findComment-4757562
+5MILLION
Dosing/flutter is THE BEST SOUND !!!
https://www.sau.com.au/forums/topic/282464-flutterdumpdose/#findComment-4758372
THANK YOU!
farken hell...
I blocked off my BOV ages ago as it was leaking and I kept it like that as it sounds better then an atmo bov and is still legal...
Boost (on standard turbo (presumadely)) is now at 1 bar and it's been like that for a while... turbo still isn't dead.
Either way, overheating and general miscare of the turbo will destroy, fluttering can be a part of this but not a main part...
https://www.sau.com.au/forums/topic/282464-flutterdumpdose/#findComment-4758925
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
