Hey all
Have cleaned out the shed and will not be using this stuff anymore so come get a bargain.
ITEM : YOKAHAMA 16 INCH TYRES
CONDITION : 90% TREAD LEFT
INFO : THESE ARE LIKE NEW , 215 / 50 / R16
PRICE : $150 ALL FOUR !!
ITEM : SERIES 1 GTST REAR WING
CONDITION : GREAT
INFO : ALL LED'S WORK AS WELL
PRICE : $120
ITEM : SERIES 1 GTST FRONT SEATS
CONDITION : GOOD
INFO : GOOD SEATS
PRICE : $100 PAIR
ITEM : SERIES 1 GTST REAR SEAT
CONDITION : GOOD
INFO : IS IN GOOD NICK
PRICE : $80
ITEM : SERIES 1 GTST BONNET
CONDITION : GOOD
INFO : WHITE, ONLY COUPLE ROCK CHIPS
PRICE : $150
ITEM : SERIES 1 GTST BOOT LID
CONDITION : GOOD
INFO : INCLUDES BOOT LOCK AND STRUTS, IS WHITE.
PRICE : $160
ITEM : ALLOY GT WING
CONDITION : GOOD
INFO : LIGHT BLUE, ALLOY GT WING
PRICE : $120
ITEM : R33 GTST UPPER INLET PLENUM
CONDITION : WORKED FINE
INFO : UPPER INLET ONLY INCLUDING THROTTLE BODY
PRICE $ 80
ITEM : R33 GTST STANDARD EXHAUST MANIFOLD
CONDITION : GOOD
INFO : WAS ON MY SERIES 2 RB25, INCLUDES HEAT SHEILD
PRICE : $70
ITEM : R33 GTST BRAKE CALIPERS AND DISCS
CONDITION : GOOD
INFO : WERE OFF MY OLD 33 GTST TRACK CAR, NO PADS CALIPERS AND DISCS ONLY!
PRICE : $350 FOR FRONT AND REAR
ITEM : SPARCO RACING SEAT
CONDITION : AVERAGE BUT GOOD FOR TRACK CAR
INFO : WAS USED IN MY TRACK CAR, HAS RAIL TO SUIT 33 GTST, HAS RIP IN CLOTH RIGHT SIDE SUPPORT
PRICE : $120
ITEM : 33 GTST JUN BL CAT BACK EXHAUST
CONDITION : GREAT
INFO : CAT BACK JUN BL MUFFLER, AWSOME SOUND
PRICE : $280
ITEM : 33 GTST PASSENGER SIDE HEADLIGHT
CONDITION : GOOD
INFO : WORKED ON MY OLD CAR, NEED A CLEAN
PRICE : $80
ITEM : R33 GTST SHELL - REGISTED !!!!
CONDITION : HAS FRONT DRIVER SIDE DAMAGE TO FRONT GUARD AND DOOR
INFO : IS A 1994 GTST, STILL HAS REGO WAS NOT A WRITE OFF ACCIDENT !! WILL COME WITH DOORS, FRONT WINDOW, CARPET, ROOF PLASTICS, DASH SURROUND AND REAR DIFF AND CRADLE , FEW OTHER PARTS, STEERING WHEEL AND STEERING SHAFT WAS CUT ALSO DUE TO IT BEING BENT IN THE ACCIDENT AND WAS UNABLE TO TURN THE WHEEL SO I CUT IT OFF!
PRICE : $1200 INCLUDING REGO AND BARE SHELL WITH PARTS MENTIONED ABOVE ONLY !
IF ANYONE WANTS EVERYTHING LISTED ABOVE ILL DO A REALY CHEAP DEAL !!
Will add pics tomorrow night or send me a txt and ill send pics to your mobile ASAP.
pm me or 0433549430 for pics
Im willing to post things but at your cost !
Cheers
Hey all
Have added the below parts to the list.
Pics are at the bottom as well.
ITEM : 33 GTST SERIES 1 SIDE INDICATORS
CONDITION : GOOD
INFO : THEY ARE ORANGE
PRICE $25 PAIR
ITEM : SERIES 1 GTST GLOVE BOX
CONDITION : GOOD
INFO : ITS A GLOVEBOX FROM A SERIES 1
PRICE : $50
ITEM : SERIES 1 STANDARD FRONT GRILL
CONDITION : GOOD
INFO : STANDARD FRONT GRILL
PRICE: $25
ITEM : SKYLINE LIGHT UP REAR GARNISH
CONDITION : GREAT
INFO : LIGHTS UP GREEN
PRICE : $40
ITEM : SERIES 2 GTST COIL PACKS
CONDITION : GREAT
INFO : WORKED FINE ON MY LAST SERIES 2 ENGINE
PRICE : $80 ALL SIX
ITEM : GTST COIL PACK PLASTIC INSERT COVER
CONDITION : GOOD
INFO : SITS BETWEEN THE CAMS OVER THE COIL PACKS.
PRICE : $20
ITEM : SERIES 2 GTST INJECTOR LOOM
CONDITION : GOOD
INFO : WORKED FINE
PRICE : $40
ITEM : SERIES 2 GTST STANDARD AIRBOX
CONDITION : GOOD
INFO : COMES WITH FILTER AND SNORKLE
PRICE : $80
ITEM : 33 GTST SIDE MIRRORS
CONDITION : GOOD
INFO : THESE ARE ELECTRIC GTST MIRRORS BUT HAVE THE PLUGS CUT OFF ( CAN BE RE WIRED )
PRICE : $120 PAIR
ITEM : 33 GTST FRONT DOOR TRIMS
CONDITION : GOOD
INFO : CAME OUT OF MY SERIES 1 GTST
PRICE : $100 PAIR
ITEM : 17x8 RIMS x3 ONLY
CONDITION : GOOD
INFO : SUIT 33 GTST, ONLY 3 AVALIBLE OTHER ONE IS WREAKED
PRICE : $120 ALL 3
ITEM : HKS EIDS
CONDITION : NEW
INFO : HKS EIDS CONTROLS THE IDLE SPEED OF THE CAR, THIS UNIT IS TO SUIT ANY RB MOTOR !
PRICE : $100 , BRAND NEW ! THESE COST $160 FROM HKS !
ITEM : TURBOSMART FUEL CUT DEFENDER
CONDITION : NEW
INFO : FUEL CUT DEFENDER
PRICE : $140 , THIS IS BRAND NEW AND STILL HAVE THE $200 PRICE TAG WHICH I PAID FOR IT ON IT !
ITEM : SERIES 1 GTST STANDARD FRONT AND REAR BAR
CONDITION : GOOD
INFO : WHITE IN COLOUR
PRICE : $100 BOTH
ITEM :
PICS ARE IN NEXT POST, MOST PARTS ANYWAY PLEASE PM ME FOR MORE INFO !
CHEERS
Sorry guys wont let me upload pics at the moment for some reason?
Send me a pm of what your after and ill MMS you pics of parts requested until i can load pics.
cheers
CONDITION : GREAT
PRICE : $40
we have spoken.
garnish is mine people :P
Passenger side headlight pic below
series 1 gtst grill sold pending payment
Light up rear garnish sold
Front gtst seats sold
PM's replied
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
