Hey guys,
I have decided to let go of my R34 widebody GTR conversion guards(Complete Front & Rears) as im in the process of selling my car. I purchased these of yahoo japan about 2 months ago. They are in excellent condition and will look amazing on and complete.THESE ARE VERY RARE ITEMS
If you have any question please do not hesitate to contact me.
Price: $750 + Postage
Contact: Via PM or 0423 929 657
Pics:
Fronts are these style
http://www.vivagarage.com.au/cart/index.php?c=87&p=438
pics of actual fronts and rears soon
https://www.sau.com.au/forums/topic/282662-r34-widebody-fenders/
Hey guys,
Pics:
would be very interested if you can send me the actually pictures of them!! can you please email them to [email protected] as i have just got my tax back and am about to do a respray on my 34 :)
ALSO they are for a GTT arent they? email me cause i dont come on here much
email sent.
hey guys i have had plenty of pm's asking for pics so ill post them up to make it easier also i forgot to mention they are for GTT and would prefer SA buyers but delivery wont be a problem.
do they match up to the gtt bumpers and tail lights. how much posted to melb 3020?
hrmm i dont think it matches the gtt bumper..
Edited by DK 33
nah you need GTR bumpers and GTR tail light covers and will get you a quote soon
