hi everyone, selling my type X gear... please dont try to bargain an already cheap price...so please if u dont agree with the price please dont waste my time. thank you...as mentioned up above melb buyers only, as i would prefere pick up only as items are big and heavy to post...
i have included the alpine website so u can verify the RRP as i aint joking with this stuff....so please no time wasters...thank you
http://www.alpine.com.au/products/index.asp
ok well what i got to offer..
1 - Alpine Type x 12" Sub SWX-1243D woofers RRP is $699 each
1 - Alpine PDX 1.1000 mono amplifiers RRP is $1,099 each
1 - Alpine iDA-X100 digital mp3 player..new release RRP is $699
All for $1200
I will sell seperate but as before dont waste my time i will list individual prices now........
12" type x sub $400
mono amp $600
Headunit $350
Pick up S.E. suburbs, springvale
Mob 0400 912 123
https://www.sau.com.au/forums/topic/283622-alpine-type-x-sale-top-of-the-range/
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
