hey guys, been a looong time since ive posted up on here mainly cause i dont live over in Australia. Well ive got an RB25DET NEO in my S chassis "240sx" here in the US, and i am in need of a replacement VCT (variable cam timing) solenoid. right now its leaking oil thru the connector and causing the car to run like crap..These engines were never sold over here so you can imagine trying to source one of these parts is not exactly easy. I would very much appreciate if anyone on here could help me out. i wouldnt even mind getting brand new one from the dealer. If one of you guys could check into that ii would be very greatful. i know im not a very big participant on this forum and for that im sorry, but I am a fellow RB owner and I am in need of some help.
thanks in advance everyone
Mark
https://www.sau.com.au/forums/topic/284158-wtb-vct-solenoid-rb25det-neo/
afaik r33 ones are the samd just different plugs which are easy to get
thanks for teh quick response, i honestly dont know what the R33 version looks like...would you happen to have a picture of it ? i have seen the VCT solenoid in my car , i have removed and have seen the entire peice without it installed in the engine. if i could see a complete picture of the VCT solenoid without it in the head it would give me a good idea if it will in fact work. not that i dont trust you at all but i have heard thru numerous people that they are in fact different. i just would like to be sure is all.
anybody?!?!
anybody?!?!
well thanks anyways guys, i had a buddy in japan actually pic me one up from a wrecked ER34. and at the same time i found the actual part number converted to a US nissan part number and i can get me one here in the state for around 100.00 bucks.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
