  • Replies 50
all i can say is Chaser FTMFW!!! ive driven one daily since july last year and there is no other car on the planet that i want or would take over the Chaser.. seriously!!
interior is a little lame, nothing that some new seats or even some car seat covers wont fix. the carbon fibre trim is real carbon fibre.
performance is excellent. ive got roughly 210rwkw with an fmic, EBC and powerFC. the engine is so smooth and has max torque by 3k rpm which is just awesome for daily driving/around town, you can get up to speed without the need to get on boost = pretty good fuel economy
thay handle pretty damn good from factory (better than the 328i e36 bmw that i used to have) ive got coilovers and swaybars and its on fkn rails. not as good as my friends r32gtst but his car is lighter so its understandable.
rear seats dont fold down which isnt that great but the boot is pretty big anyway
then again, i supose im pretty biased
fyi - the 4WD chaser was only released as a 2 litre non turbo auto. you can get 2j chasers but they are NA
check out www.jzx100.com for more info :D
1480kgs dry. my car is registered at 1520kgs, it was weighted with a full size spare, big sound system and a full tank of petrol
with me in it its 1660kgs (yes i weigh 140kgs) so its a bit heavier than my friends r32 gtst at 1380kgs
Edited by nerm
  • 1 month later...
my bro got one recently 1996 turbo, auto model, all i can say is its a good car comparing it to a skyline like a r33 of the same year its alot better, 4 airbags, xennon lights, more leg room in rear. make more power stock 206 kw, more torque than a r34! comparing it to my r34 sedan its only a matter of personal preference as feature wise its got more, but the auto would be better if it was tip tronic. feels abit heavier than a skyline thou but for daily driving who cares. ;)
Decent car that requires nothing much to get it going great.
I'll only consider the 1JZ manuals and currently, prices are dropping.
Under 20k will get you a nice example.
Availability of aftermarket parts is great too....with more than a few ppl here selling stuff like coilovers and coolers for the chaser.
I certainly wouldn't mind getting one....lowered on coilovers with some tough rims. But this is IF the gf will let me get one. She's had a bad experience in Japan involving one (long story) :P
  • 1 month later...
I have been considering one also.
But 90% of them are autos. Starting to research if its worth converting them to manual. I also heard from someone thats its as easy as putting in a manual ecu and excepting everything to work.
Anyone converted an auto to manual?
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
