Well since the old thread seems to have been deleted, will post this up again.
For those interested, im trying to organise a cruise for te 14th of December. At this point in time meetup will be at the Caltex service station in Queanbeyan at 10:00AM for a 10:30ish leave. Probably head down towards batemans bay, but can decide that amongst those who come on the day.
Would be great to see everyone out, and it should be nice cruising weather!
Hope everyone (or most) can make it.
https://www.sau.com.au/forums/topic/28437-cruise-14th-december/
hi guys found out there are gonna be a few other clubs coming along as well. so far they are
j-racing
shogun
mr2 club
garage titan
so it'll be a good cruise and good to put names to faces. if you guys don't mind waiting for most of them to arrive at around 11ish the latest at the servo as j-racing, shogun and mr2 club meeting at 9:30-10:30 at mt ainslie then hopefully in time, cruise to the servo in q.b.n. where we'll meet up.
p.s. bring 2 way radio's to keep in touch along the cruise if you have any if not supercheap have them for around $40-$50 for 2.
:cheers:
don't get too excited, depending on wheather.+ if anyone decides to actually show up.
but then again bring you're camera's/digi cams etc and spread the word the more the merrier. gtr is getting restless being driving for short blasts around canberra and wants to stretch it's legs.
specially round the clyde or is it macquarie pass?
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
