Complete 32 Gtr Wrecking, Perfect Interior, Aftermarket Parts, All Panels, Nismo Wheels,with Semi Slicks, 33 Gear Box Nismo Dash
Hi, Clutch push or pull? Price?
Also need all 4 abs-sensors and lower radiator hose. Price if not sold?
Best regards
Petter, from Norway
  • Replies 104
Posted Images
The sensors are in the hubs, only one small screw that holds them in place.
Petter
Hi Petter
I will check it out I gather you can't PM
Cheers
Hi Petter
Cheers
Radiator, shroud and lower bar is sold, yell out if you are after anything else best to PM or get in contact by phone 0408 188 777.
Cheers
Updated add, if I have mssied amyone with PM etc just yell out, Regards Taylor 0408 188 777
Cheers
Panels
Guard Driver side great condition 275
Left door includes hinges & lock and handles 160
Right Door includes hinges & lock and handles 160
Side Skirts with pods 300
Window mechanism with motor 100 each
Rear Bumper 200
Rear Reo 175
Interior, great parts for cleaning up your interior
Door Trims Great colour Front and back including all clip handles 300
Centre surround around stereo and Aircon 100
Glove Box with Key 70
Centre Console including glove box lid, strong colour 120
Leather Gear & Hand Brake Genuine great condition 80
Dash No bubbles/lifting two small screw holes easy fix, hard to notice 150
Carpet 120
Mats 100
Roof lining perfect 90
Boot complete including plastic and trims 170 no stains
Glass
Front windscreen with all wiring and aerial, genuine 475
Rear windscreen with all wiring, Genuine GTR thinner & lighter 575
Drivers side quarter glass 130
Passengers side quarter glass 130
Light & Indicators
Head Light Passenger side standard 90
Head Light right Driver side standard 90
Gauges
Greddy Exhaust gauge and wiring 120
Climate Control 90
Wheels
Space saver 45
Drive Line
Gear Box 33 GTR Good condition fits 32 as well , on Hold 900
Twin plate Direct Racing Clutch, great for performance & daily low klm 1180
Front Diff 270
Rear Cradle 350
Tail shaft 200
Drive shafts with boots 120 each
Suspension
Lower control arms factory with N1 brake ducting 100
Front sway bar 80
Rear hubs 190
Engine Bay
ABS Unit 350
Brake Master cylinder 180
Starter Motor 150
Power Steering Reservoir 90
Coolant bottle 45
4WD Computer 120
Engine Harness $600 new sell at half 300
Full Body Harness, inc fuse box, no cute TBA
Injector & resistor pack TBA
Air flow meters 145 each
HKS air pods including arms and braces 180 set
Exhaust cat back, pretty big need to measure part stainless 580
Miscellaneous
Fuel Door 60
Fuel tank 70
The 3 centre gauges, you know voltage, boost and water temp one.
It has its own wiring to it and that is what i need, the plug that plugs into it. so yea you need to cut it.
Think you can remove it? if so how much you want?
cheers!
Edited by VXL
cheers!
Hi, I want to sell the harnes complete with no cutting
Zardos I will get back to you today
Cheers
Ok, but the only easiest way you can remove it is by cuttin the wire.
Let me know if you reconsider!
Cheeers
still got the Recaro seat?
VXL, harness has already been removed without cutting so sorry not keen to split.
Seat already sold PM sent
Dash sold
Cheers
  • 6 months later...
Door Trims sold and carpert sold, feel free ot yell out about remaining parts
Cheers
Hey Taylor
Keen on Centre surround around stereo and Aircon
Can you please post -> Canberra 2905
Please pm acct details
S!N
0404 822 143
Hi Guys
Reverse lights are sold an dI will get in contact with you Sin regards the Air Con
Cheers
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
