i think its like 3 months, b4 they make you do an inspection?
i let mine go on my daily for like 2months.
and you just phone and make the payment.
i wouldnt risk it tho, not liek your rego starts from the date of payment.
internet payments stop working day after payment is due.
I think 30 Days after the date on the invoice issued to you.
Although after the date on the invoice, your CTP Insurance is void, so where possible, pay the rego before that date.
After 30 days past the due date, your car becomes deregistered and they'll want the plates back?
So can you drive around in that 30 days?
legally ??
NO your car will be unregistered but you have a 30 day grace period in which to pay it before your car requires a pit examination to be re licensed .If you are caught driving it in that 30 day period it can be confiscated under their new laws for 28 days
This question was calling me!!!!!! ahaha
Your rego expires on midnight of the date listed, so you get 15 days grace after it has expired, however you can renew the registration of your vehicle up to 3 months after it has expired without incurring a penalty or having to take your car over the pits!
:laugh:
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
