hey mate,
i was just wondering if you have the following:
- ashtray
- bottom half of the steering column casing &
- rear bumper
cheers,
melvin
edit: was also looking for stock grill if you have it.
Edited by melvin
  • Replies 95
Posted Images
would you be interested in selling me the black plug that goes into the back of the factory head unit?? 2 x 6 pins orange and grey wires only
i need this part willing to pay if its the right one
pm me please
hey mate,
- ashtray
- rear bumper
cheers,
melvin
OK Dave has advised $200 for the grill, ashtray and column casing... Delivery on top ($30 as a guestimate), pickup welcome
pm me please
There is possibly this plug on the new GTR, he will check it out and get back to you :)
hey anna,
just wondering where abouts are you located for pickup purposes and do you have the screws for the column casing??
how much for just the ashtray and case??
cheers,
melvin
Pickup is Western Sydney - Toongabbie
He has the grill at $150 in the first post - so would assume the ashtray and column piece would be around $50 picked up but Il get him to confirm in the morning as he might of discounted for bulk lot. The screws will still be there as it is still attached to the car!
any news on the price ms??
cheers,
melvin
how much for 2 headlights if u got em? can pick up...also front bumper reo?
No headlights..and the REO is fubar'd..
so both bonnets are gone?
Yup both sold sorry...
Dave is currently stripping the entire car and a new thread will be up shortly with the parts remaining.
Cheers
Anna
  • 4 months later...
  • 4 months later...
Do you have a lighter/power socket with the short wire/plug to go into the loom behind the dash?
And a stereo cage un cut? GTR door cards, and maybe a rear wing.
hey buddy do you still have the GTR shells?
im thinking about the one for 1200 whats the damage like? or is the shell streight?
a lil more info.. if the shells good, consider it sold.. just would like as much info on it as possable
cheers ash..
just pm me thanks
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
