I have for sale a 93 Nissan Skyline. The motor has been rebuilt with larger head gasket, acl race bearings,
forged pistons and a n1 oil pump while in bits the motor was chemically cleaned and the block was re-bored.
All was done approx 50,000kms ago. while this was done the gearbox was also rebuilt and fitted with a heavy duty clutch.
the turbo has been high flowed and has a larger actuator, cooled by a GReedy front mount cooler and custom air box,
excess air is released through a HKS super Seq blow off valve and exaust is taken care of by a 3 inch HKS exaust.
The car has a daughter board chip and apexi AVCR controls the boost and fuel, backed up by a malpassi fuel reg and 040 fuel pump.
BEST OF ALL RECIEPTS FOR EVERYTHING
The car has also been professionally lowered and has front and rear whileline strut brace's, it currently sits on mutli spoke 18's.
PRICE-$12,000
Call nathan on 0420443664 or email [email protected]
https://www.sau.com.au/forums/topic/284866-r33-forged-12000/
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
