Nokia N97 - $850
Touch screen isn't for me, camera is great though, I am cutting my losses and going to buy an E75, unfortunately I'm stuck on a f**king $69 cap, so I have to sell my handset and buy a new one cos they won't let me change handsets >.<
Located in St.Lucia, Brisbane
(can post)
Item will come all wraped up in oem plastics and box, practically brand new, works fine, the userbility factor is just not for me, I prefer buttons.
Contact Michael on 0413 504 084
Thanks,
https://www.sau.com.au/forums/topic/284942-nokia-n97/
you might wanna drop the price a bit man. you can buy them brand new in box never touched straight off the shelf from shopbot for under $800 from unique mobiles, becex tech, portagadgets, citishop, optus, bluefly mobile and more...
Just thought you might wanna know why you r getting no hits.
https://www.sau.com.au/forums/topic/284942-nokia-n97/#findComment-4787188
Are you serious????????? The reason I went on a plan was cos VODAFONE wanted $1200 for me to buy the phone out right! :)
Edited by GHOSTrun
https://www.sau.com.au/forums/topic/284942-nokia-n97/#findComment-4787835
I checked out that site, all I can say is this economy shit is f**ken bullshit. The price of them has dropped down to 800'ish, a few months ago they were selling for over $1100, what a f**ken rort :P
Price drop to $800
Edited by GHOSTrun
https://www.sau.com.au/forums/topic/284942-nokia-n97/#findComment-4789203
Iv got one of these.
Its a really great phone for those who like touch screen or the QWERTY key board.
Heaps of cool "iPhone like" features.
GOODLUCK mate.
many apps out for it yet?
https://www.sau.com.au/forums/topic/284942-nokia-n97/#findComment-4790542
New First Post since it won't let me edit my first post:
Nokia N97 32GB - $700
Touch screen isn't for me, camera is great though, I am cutting my losses and going to buy an N95 8GB, unfortunately I'm stuck on a f**king $69 cap, so I have to sell my handset and buy a new one cos they won't let me change handsets :D
(can post)
Item will come all wraped up in oem plastics and box, practically brand new (less than a month old), works fine, the userbility factor is just not for me, I prefer buttons.
Contents
- Nokie N97 32GB
- Nokia Battery
- OEM Charger
- Nokia Stylus for optional use on touch screen
- Nokia Cleaning Cloth
- Nokia USB Cable for PC connectivity and also chargers the phone whilst connected
- Nokia OVi PC Software
- Nokia Car Charger with dual adapter for different sized power plugs (can charge all Nokias)
- Nokia Headphone jack/volume control for handsfree
- Nokia Manuels/Brochures etc
- Nokia OEM Soft Case
- Custom made hard case (cost me $40 to buy and have modified to fit)
Thanks,
https://www.sau.com.au/forums/topic/284942-nokia-n97/#findComment-4806747
Ive got an N95 8gig, little bit of the usual wear marks on it, interested ina trade with cash your way?
If so i will get pics of it.
Maybe, are you local? If so I'll check it out, but yeah $650-700'ish is enough for me to buy a brand new one which is what I'd prefer to do :D
https://www.sau.com.au/forums/topic/284942-nokia-n97/#findComment-4806778
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
