Hey guys this is my toy, only mild mods at moment. hoping to get a bit more done too it in the next year or so, want hopefully close to 300 rwkw
out of my 20!! if no success ill do a different engine conversion. eg ls1 or 2jz :)
Engine
RB20DET conversion
JJR FMIC,
3inch Apexi Cat back
NGK plugs
Dr. Drift custom tune
Gates sport timing belt and tensioner
Driveline
5 Speed manual conversion
Extreme extra heavy duty solid button clutch
R33 GTST Shimmed LSD
Wheels/Brakes
S15 Front Suspension Conversion
Lovells Sport Springs
KYB Struts
Hicas Lockout Bar
5 stud Conversion
R32 GTR Front brakes
R33 Rear brakes
Volk GTP Rims (17x9.5 +33, 17 x 8)
Rays gold wheel nuts and valve caps
Bendix Brake pads
Other mods
Bosch 044 fuel system
52 mm aluminium radiator
Thermo fans
Cold air intake
Recaro Drivers seat
Momo gear knob
Speco Boost gauge
Double din dvd player/ screen
Alpine Type R front splits
Alpine Type R rear Splits
Clarion 4 way Amplifier
Battery in boot
https://www.sau.com.au/forums/topic/285085-my-ceffy/
  • 1 year later...
  • 11 months later...
Yeah 32 centre console, need to get hold of a ceffy one. I reckon if Benny seen it now he would cry, bit knocked around from sitting in the shed for a year or so. It's back on the road again now running the same 20, very very boring now. Any ideas of cheap mods to get it going a bit quicker? Currently not working so on a budget for now :/
Was thinking 34 highflowed turbo on 17psi?? Thoughts?
https://www.sau.com.au/forums/topic/285085-my-ceffy/#findComment-6046517
send your std turbo in to hypergear ... or buy a china td06 (which is what i'm about to do) , or buy my gt2530 off me so i can buy said td06 :whistling: . the trick to making rb20s' (imo) is keeping things like cooler and pipework as short and small as possible (i.e smallish cooler , pipework as short as possible , i've been looking into smaller radiators and running upside down coolers/one sided coolers to shorten piping up , the only issue i'm getting is keeping the std inlet mani (seems to work best for rb20)
can you even get defected in tassie?
high mount and screamer pipe :nyaanyaa:
Well you can , if you drive silly enough pinch.gif , apparently popo is coming down on 'illegal' mods and we're gunna be line ball with other states , then i'll move to perth :P
Edited by toffy
https://www.sau.com.au/forums/topic/285085-my-ceffy/#findComment-6050778
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
