I turn 28 in January and I consider myself to be a "relatively" mature owner of this Skyline. I will be placing this on the CarPoint.com.au market shortly. However, I am willing to try sell on SkylinesAustralia first. I am the first Australian owner of this vehicle.
I don't really want to sell my Skyline, however I have a genuine reason for sale and that is; I have recently bought a new toy...A GTR! It's getting a little expensive on the pocket insuring and running two Skylines. Plus, I'd like to throw a few dollars into the GTR.
No encumbrance (in other words; no finance) on this vehicle, I own the car outright. Feel free to check this on the VICROADS website. However, I will only provide the registration number for genuine interested buyers. Registration runs out end of October this year. Details are as follows;
Sound system (not even 3 months old);
Cost $3,400 (have receipts & warranty)
- Pioneer Double dimm head deck AVICF900BT (GPS, DVD, DivX, iPhone 3G, MP3 etc.)
- JL Audio 4 Channel Amp
- JL Audio 2 Channel Mono Block
- JL Audio Splits - front
- JL Audio 2way – rear
- Kicker 07DCVR122 2 x 12in ported subs
- Full Audioline wiring kit
Wheels;
BBS LM Edition Gold 18x9 (rear) 18x8 (front) +$3000
Tires;
Bridgestone "something"
265/45/R18 Rear – good tread
235/45/R18 Front – poor tread, will need replacing for RWC, inside of tyre starting to wear
Suspension;
NISMO, S-Tune adjustable suspension (factory fitted – certificate comes with log books)
Exhaust:
Fujitsubo hi flow exhaust system twin from cat back (I think this was also fitted factory, I am not sure though)
Turbocharger;
400HP rating Garrett GT25/2871R (have receipts $2,200)
Ball bearing cartridge, steel turbine and compressor wheels. Bit of an upgrade from the standard thrust type baring, ceramic turbine wheel and plastic compressor wheel.
Direct OEM fit, no fabrications were needed, looks 100% standard. Heat proof braided oil feed and water cooling lines. Genuine Nissan new exhaust studs, gaskets and nuts were used also. Boost controller, actuator, plumbing, dump pipe etc – all standard. This is the only modification that has ever been carried out on this engine. Engine has only been dyno tested once after new turbo was fitted to check air/fuel ratios, and the car also pulled 199rwkw (have dyno sheet). Fuel ratios were fine for the upgraded turbo, however minimal ping was detected whilst on dyno and crank timing was reduced by 2 degrees. So, having said all that; I didn't just go slap on a bigger turbo and go nuts, I took all the necessary precautions and thoroughly tested the new setup. I have the original standard turbo also. Turbo waste gate creeps open at 10PSI, maximum boost witnessed 13PSI on a cold night. So, 199rwkw at 12psi – no stupid boost levels ever pumped into this engine, given standard fuel setup. A healthy standard R33 will pull on average 130 to 160 rwkw, with a filter and exhaust.
Service History;
Major Service just performed @ 95,000k's ($500-have receipts);
- Genuine Nissan Waterpump
- Genuine Nissan Timing Belt
- Genuine Nissan Idler and tension pulleys
- Genuine Nissan Front main seal
- Plugs BKR7E
- Oil Filter Ryco
- Motul Turbo light oil
- Fuel Filter Ryco etc.
Clutch:
($450 - have receipts) work carried out not even three months ago.
- EXEDY Heavy Duty full face clutch kit including flywheel machining
- Rear main seal
- Gearbox main seal
- Spigot bush replaced
- Thrust bearing (part of the kit)
Interior is spotless, body is dead straight, paint in excellent condition and especially the head lights still look new – not dull or faded. I am confident this car will not need anything for roadworthy – just two front tires. The synchro's in the gearbox are perfect! If you'd know Skylines, they have a tendency to clash second gear a little. I believe this gearbox has had a respectable life, and the whole car for that matter.
Asking $16,900 ono with everything
OR
$14,400 ono WITHOUT Sound system
I'd prefer to not sell the car WITHOUT the sound system, as I do not have the time to remove it. It took a whole bloody weekend to put in, never doing a job like that again. However, work was carried out professionally (soldered, heat shrink, electrical tape etc.), I do IT networking so have a broad knowledge about electronics. So, the stereo ain't gonna blow up or anything!
Oh, and by the way; I removed the side skirts, I didn't like the look of them! But I still have, they will come with the car if wanted to put back on, also the rear pods.
Not interested in swapping , but I will consider swapping with a new R35 GTR :)
Well that was one hell of a write up, got a bit carried away there and a little self indulgent!
Anyway, my contact details are as follows;
Mobile: 0409 652 542 - Melbourne
Email: [email protected]
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
