  • Replies 185
sucks when thief's steal.... i have been looken around up on the sunny coast and no luck.. but i have mates all round that work on servo's and stuff and they keep me posted... hope it turns up soon... it looks mint :laugh:
i'd go on a rampage if someone stole mine...
yeah I would get onto all the servos if I could but there are too many. just thanks for everyone for the support and co-operation.
Just as a matter of interest, how did you manage to get insurance without a alarm? i thought that was pretty standard for insurance policies on imports these days!?!?
I was able to get market value insurance, I wasnt too worried about insurance as when I bought the car it had done a shitload of k's and I was just gona run it down over years, instead I did the opposite and spent like 5-6k on it lol so yeah :S should have got an alarm and immobilizar
I have released the footage, Was unable to upload to SAU as the max upload is 2mb so I uploaded it on boostcruising, please go to this link to watch it. cheers
http://www.boostcruising.com/forums/index....entry1284553426
it shows the two blokes walk past the camera you get a pretty good image of them both, then one guy leave the carpark, then the car exit the building, they both have walkie talkies as well. go to this link and download the footage but I think you have to download a codec as well. its an AVI file so get a player that plays aVI files and download a codec. just go to google and type codec download to get one. the footage link is below.
http://www.boostcruising.com/forums/index....t=0&start=0
yeah theres a guy trying to convert it hopefuly for me. the footage is going to be played on 9 news tonight and also ten news either tonight or tomorrow night.
Cheers guys for all your help
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
