Hey all,
Had a bit of bad luck, the motor has lunched itself a bit. The bolt holding on the idler snapper (10mm smegging bolt) and the timing belt let go and has bent the valves etc... So I would like to sell it all in one go, I just dont have the energy for it anymore - Im not going to part it out, so dont bother asking.
Has rego, and a whole lot of good stuff with it, looks pretty stock and was pretty quick and fun to drive. Below is a bit of a list of some of the bits and pieces that will come with it:
December rego
New Federal tires
New stuff: walbro fuel pump, oxygen sensor, front drive shafts, coil packs,
Other stuff: rb25 and rb20 turbo, r34 intercooler plumbed into stock location, split dump, 4" hks exhaust, hicas lock bar, coilovers
Stock interior in great condition, carpets and dash are like new - no bubbles.
Few other bits and pieces. I have spent a lot of hours cleaning it up and sorting things out with it, so it should be a good little project for someone
I would like about $4500, but very negotiable, I really need to sort out some transport for myself. Cheers all
Dave
https://www.sau.com.au/forums/topic/285449-fs-r32-skyline-gts4-blown-motor/
Swaps? I am keen on getting a liberty wagon, must be manual tho :P
Oh, and I can put on some other rims, still r32 rims with less tread on the tires to drop the price a bit more if anyone was interested
Edited by Medium Dave
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
