Hey
I Have,
1 x Set of Ferodo DS2500 Brake pads ( Part number # FRP3077H )
Dimensions are 152mm x 54mm x 17mm
These Pads suit all G4 Racing 8 piston calipers, D2 and Ksport. They also suit the AP Racing 6 Piston Units.
They are brand new! only been trial fitted to calipers, Come boxed in the Original Ferodo Box.
These pads cost around the $370AUD mark depending where your buying them from. Some Australian Suppliers will try and sell them for $400 and up!
Feel free to PM me to make a reasonable offer or reply to this post, Or you could put a bid on these on eBay, bidding has started at $260AUD! I will post these anywhere in Australia.
Grab yourself a bargain! excellent pad for someone wanting a balance between road and track.
More info on these pads can be found at
Thanks for looking :)
Cheers.
Edited by rbr31andrew
Have Relisted the pads on ebay! Feel free to make me an offer. Need these gone!
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...%3D1&_rdc=1
Asking price is $250 , Thats a saving of over $100
There must be someone with a set of G4 racing 8piston, Ksport 8 piston or AP Racing calipers that need a set of Ferodo DS2500 for Track days/Road who want to save over $100 dollars on the retail price ? ?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
